Looking for documentation to use /server/admin/generatetoken that is hard coded in an application and set up clientID/Secret for 2 specific hosted feature layers. This is a federated enterprise setup.
Thank you
This article should explain it, the application will have access to all the content where it is located and any groups it is in.Authentication—ArcGIS REST APIs | ArcGIS Developers
Working with different authentication schemes | ArcGIS API for Python
User authentication | Documentation | ArcGIS Developers
Hope it helps
Regards
Henry
Exactly what we are running into. Was straight forward with an unfedereated stand-alone server but these Vector Tile services have to be on an Enterprise setup.
Following. We need to do the same thing. I see how to create an "application" item that has a client ID and secret, and I am able to generate a token using that, but I don't understand how that grants access to content, or how to specify which content it should have access to.
