It would be great to use portal authentication to be able to login to ArcGIS monitor instead of having to maintain users separately. This would also allow for single sign on if configured within the portal.
Hello @DavidMcCorkindale1,
When you say portal authentication, do you mean the built-in user store, where you provide a username and password in the Portal for ArcGIS login screen? Or are you referring to a SAML or IWA login experience?
Josh
Hi @DavidMcCorkindale1,Your idea sounds similar to this submitted idea, Support AD or LDAPS identity stores.
Can you please review and confirm if this is the case?Another consideration: If Monitor were to use the same logins as enterprise portal members, then we may need to also follow the ArcGIS User Type model in portal. Thanks,
Hi @DerekLaw and @GeoJosh
This is not really similar to AD or LDAP approach as we don't use either of these in our portals. We would like to see an OAuth implementation that would enable any type of authentication (built-in, saml, etc) provisioned in the portal to be allowed as a login. This is the same approach that is used by the ESRI Geoportal application with authentication taking place against the portal and portal groups used to control authorization within the application.
Our monitor users are all admins within portal so are already licensed under the ArcGIS user type model.
Thanks
Thanks for the additional information/context on your requirement. 👍
This is a important requirement for us too. Especially in a large environment it should be possible to use the same single sign-on process for the ArcGIS Monitor as defined on the ArcGIS Portal (SAML or in our case OAuth/Open ID Connect). The people who use ArcGIS Monitor are all licenced under the ArcGIS user type model.
Yes, this integration ("federation") with Portal members, whether they are built in or SAML based, would be needed to make Monitor really part of ArcGIS Enterprise.
Dears,
I agree with the ideas and comments that you have posted.
In addition, from my experience working with both ArcGIS Enterprise and ArcGIS Monitor, I miss the concept of ArcGIS Identity, which allows me to access ArcGIS Monitor content with a single set of credentials.
This way, users would not need to remember another set of credentials, user management could be centralized and managed from the same Portal for ArcGIS, and security policies and session management could also be managed, regardless of the identity provider (built-in or third-party).
Many thanks
Borja
Please see my post in this other similar proposed Idea submission for ArcGIS Monitor,https://community.esri.com/t5/arcgis-monitor-ideas/identity-mangement-leverage-portal-user-store/idi-p/1705946
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
