Plz help me to figure out why when I am converting my 32 float bit raster to ascii my values changed? Why does this happen?
try scaling the raster up by a factor of 10 or 100 first, just remember what you scaled by and see if it goes to ascii then
Do you think the problem is because the raster is float and not integer?
Did you marked it assumed answered? I thought the scaling and conversion to integer or just the scaling would have solved it. If not, you will need to provide some more information
I am still working on it. I am still having hard time. My raster is at 1m cell size and need to be at 32bit float.
why the need to get the raster to ascii?
why did you bring in the ascii back into arcmap?
a description of what you are doing would go a long way to identifying your process
