We are beginning to create and publish maps to AGOL, but I am baffled by what seems to be the workflow in order to do this. Can you share your experience publishing maps?- Start with a base map that has vector layers CA Albers, NAD 83
- Roads
- Counties
- City Boundaries
- Hospitals
- Fire Stations
- Police Stations
- Emergency Operation Centers
Receive incident data for the map
- Road closures
- Shelters
- Road Closures
- Evacuation Areas
- Fire perimeters
Publish Map for situational awareness with user control of visibility of content. (Turn on/off layers)
- Create an .mxd for each layer (12)
- Re-project each .mxd to Web Mercator
- Publish 12 services
- Add each service to AGOL
We seem to have to do all this extra work just to get it to a web mapping app just to be able to turn on/off layers individually, because if we just publish the map .mxd (after re-projecting), all layers are all on or all off.Is this correct or is this WAD (works as designed)? This is a lot of time spent trying to get situational awareness in an emergency.Thoughts? D.
