In ArcMap one could see the feature count of <all other values> when configuring symbology but showing <all other values> in legend was deactivated.
In ArcGIS Pro when showing <all other values> in the legend is deactivated it is deactivated as well in the Symbology Pane and therefore the count of features out of range is not visible.
When “Show all other values” is activated it is visible in legend and in Symbology Pane:
When “Show all other values” is deactivated it is invisible in legend and in Symbology Pane:
When <all other values> is checked, it is visible in the legend and in the layer properties:
When <all other values> is unchecked, it is not visible in the legend but still in the layer properties. Especially the feature count:
In addition, in ArcMap the feature count is visible by default, in ArcGIS Pro it has to be activated. And In ArcMap the total count of all features is visible but not in ArcGIS Pro. Feature count and total count should always be visible by default in Symbology Pane and automatically updated when data is changed.
Enhancement
It would be very useful if you could add the following functionality to ArcGIS Pro:
- Show <all other values> with the feature count in the Symbology Pane in ArcGIS Pro even if <all other values> are deactivated in the legend
- Show the total count of all features in the Symbology Pane
- Show the feature count by default in the Symbology Pane in ArcGIS Pro
Use Case
Sometimes data in an existing dataset changes. The symbology for the layer remains the same. We need a functionality to quickly check if we have data in our dataset that is out of range.
Sometimes we get a new dataset and want to symbolise it with the symbology of an existing layer. Here we need a functionality as well to quickly check if we have data that is out of range.
In ArcMap these two workflows were pretty straight forward, and we used it on a daily basis. In ArcGIS Pro the workflow is more complicated and error prone.
What in ArcMap can be done with a double click on the layer to open the layer properties and an optional second click to open the Symbology tab, needs at least six clicks in ArcGIS Pro (open the Symbology Pane, activate “Show all other values”, activate “Show count”, deactivate “Show all other values”).
