we are trying to create a trace network on a dataset in an oracle sde, but this error is displayed: 001904: The SDE or DBMS administrator cannot create a distribution network or a trace network.
full error message
001904: SDE or DBMS admin user cannot create a utility network or trace network.—ArcGIS Pro | Documentation
Hi, thank you for your replie. i'm trying to generate the trace network with the sde profile, which is the owner of the database.
You must load the trace network into another data owner for the tool to work: https://pro.arcgis.com/en/pro-app/latest/help/data/trace-network/create-a-trace-network.htm
Hello, thanks for your answer. we have created a database user and we shared with him the creation privileges of the class set concerned, and for the portal, we are connected by the same user. but we have this problem
It still looks like the trace network is still owned by the SDE user. If that is the case, you need to copy over (or reload) the trace network in as the database user that you created. That DB user must have all the permissions to own data (https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/privileges-oracle.htm).
