Hi everybody, I am having the issue of white space above the Header. Header is customized as below:- any suggestion is highly appreciated :-
<nav class="navbar navbar-default navbar-static-top first-tier"><div class="container"><ul style="padding: 30px 0 0 0;" class="nav nav-pills pull-right" role="navigation"><li><a href="https://" "/search?collection=Dataset">Data</a></li><li><a href="https://" "/search?tags=Pdf">Documents</a></li><li><a href="https://" "/MapAndAppGallery/index.html?appid=7b9a21a3e33e45a3abcf6ebc694aa...">Map & Apps</a></li></ul><div class="navbar-brand"><div class="site-logo"><img src="https://" "/content/items/28daf41d36b84a9a93d567f9267665ea/data" alt=""></div></div></div></nav>
A couple things: the <div>'s you set to not display are empty. Also, you can assign multiple classes to a tag. And finally, I think the .hidden classes are to hide things instead of setting the .visible to not display.
I am not a bootstrap or HTML expert, but give this a try:
<nav class="navbar navbar-default navbar-static-top first-tier"> <div class="container"> <ul style="padding: 30px 0 0 0;" class="nav nav-pills pull-right" role="navigation"> <li><a href="https://data-airdrie.opendata.arcgis.com/search?collection=Dataset">Data</a></li> <li><a href="https://data-airdrie.opendata.arcgis.com/search?tags=Pdf">Documents</a></li> <li><a href="https://airdrie.maps.arcgis.com/apps/MapAndAppGallery/index.html?appid=7b9a21a3e33e45a3abcf6ebc694aa...">Map & Apps</a></li> </ul> <div class="navbar-brand"> <div class="site-logo hidden-xs hidden-sm"> <img src="https://airdrie.maps.arcgis.com/sharing/rest/content/items/28daf41d36b84a9a93d567f9267665ea/data" alt="" > </div> </div> </div> </nav>
That white space with the search icon? That's the Global Navigation bar. Turn it off under Site>Settings>Interactions
@dgiersz_cuyahoga Thank you again. I added new classes (with style as display: none) as follows but with no luck. I am very new with Bootstrap in html, could you please point out where and what am I missing to remove the logo on mobile view? Thank you so much!
<nav class="navbar navbar-default navbar-static-top first-tier"><div class="container"><ul style="padding: 30px 0 0 0;" class="nav nav-pills pull-right" role="navigation"><li><a href="https://search?collection=Dataset">Data</a></li><li><a href="https://search?tags=Pdf">Documents</a></li><li><a href="https:///apps/MapAndAppGallery/index.html?appid=7b9a21a3e33e45a3abcf6ebc694aabea">Map & Apps</a></li></ul><div class="navbar-brand"><div class="site-logo"><div style="display:none;" class=".visible-md-*"></div><div style="display:none;" class=".visible-sm-*"></div><img src="https:///28daf41d36b84a9a93d567f9267665ea/data" alt=""></div></div></div></nav>
You can try adding classes to the "site-logo" to hide it on small screens.
Options based on screen size:
https://getbootstrap.com/docs/3.4/css/#responsive-utilities
@dgiersz_cuyahoga Awesome, that worked perfectly, thanks alot. I am now having the issue with Mobile view on my header as well as footer. They are overlapping with each other. Please see the attached image. Any idea to solve this?
