<script type="text/javascript"> var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www."); document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E")); </script> <script type="text/javascript"> try { var pageTracker = _gat._getTracker("UA-xyz-x"); pageTracker._trackPageview(); } catch(err) {} </script>
I use it on my site directly from within flex. (not flexviewer though)
<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" minWidth="955" minHeight="600" addedToStage="onComplete()"> <mx:Script> <![CDATA[ import com.google.analytics.GATracker; import com.google.analytics.AnalyticsTracker; public var tracker:AnalyticsTracker; private function onComplete():void { tracker = new GATracker( this, "UA-111-222", "AS3", false ); tracker.trackPageview( "/Initial"); } protected function b1_clickHandler(event:MouseEvent):void { tracker.trackPageview( "/Widget1_load"); } protected function b2_clickHandler(event:MouseEvent):void { tracker.trackPageview( "/Widget1_table"); } protected function b3_clickHandler(event:MouseEvent):void { tracker.trackPageview( "/Widget2_load"); } ]]> </mx:Script> <mx:Panel id="p1"> <mx:Button id="W1_load" click="b1_clickHandler(event)"/> <mx:Button id="W1_table" click="b2_clickHandler(event)"/> <mx:Button id="W2_load" click="b3_clickHandler(event)"/> </mx:Panel> </mx:Application>
I loaded the compiled version in our Flex 2.5 version ... and when i open the viewer the hour glass runs endlessly. Any suggestions? Thanks much.
<widget config="widgets/GoogleAnalytics/GoogleAnalyticsWidget.xml" url="widgets/GoogleAnalytics/GoogleAnalyticsWidget.swf"/>
