I've created a model in ArcGIS Pro ModelBuilder which attempts to carry out the following:
- Variable: Database connection (sql server)
- Make Query Layer (input = Database Connection, output = "Dwellings SQL")
- Make Feature Layer (input = "Dwellings SQL", output = "Dwellings")
Then using the code in the following resource:
https://www.esri.com/arcgis-blog/products/arcgis-pro/mapping/publish-and-overwrite-web-layers-in-modelbuilder/
I created a toolbox which should publish (overwrite) a layer called "Dwellings" in our AGOL account. I have tweaked the code in the ScriptTool function as such:
def ScriptTool(map, service, summary, tags, description, overwriteService, enableEditing, enableSync, enableWFS, timezone, share_public, share_organization, share_groups, outdir):
"""ScriptTool function docstring"""
# Set output file names
sddraft_filename = service + ".sddraft"
sddraft_output_filename = os.path.join(outdir, sddraft_filename)
# Reference map to publish
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps(map)[0]
selected_layer = m.listLayers()[0]
# Create FeatureSharingDraft and set service properties
sharing_draft = m.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", service, [selected_layer])
sharing_draft.summary = summary
sharing_draft.tags = tags
sharing_draft.description = description
sharing_draft.credits = "My Credits"
sharing_draft.useLimitations = "My Use Limitations"
sharing_draft.overwriteExistingService = overwriteService
# Create Service Definition Draft file
sharing_draft.exportToSDDraft(sddraft_output_filename)
outsddraft = sddraft_output_filename
arcpy.AddMessage("Service definition draft created")
# Modify capabilities
if enableEditing or enableSync:
ModifyCapabilities(sddraft_output_filename, enableEditing, enableSync)
if enableWFS:
EnableWFS(sddraft_output_filename)
# Set time zone
if(timezone != ""):
property_set = [{
"key": "dateFieldsRespectsDayLightSavingTime",
"value": "true"
"key": "dateFieldsTimezoneID",
"value": timezone
SetTimezone(sddraft_output_filename, property_set=property_set)
# Create Service Definition file
sd_filename = service + ".sd"
sd_output_filename = os.path.join(outdir, sd_filename)
arcpy.StageService_server(sddraft_output_filename, sd_output_filename)
arcpy.AddMessage("Service definition created")
# Upload to portal
output = arcpy.UploadServiceDefinition_server(sd_output_filename, "My Hosted Services", in_override="OVERRIDE_DEFINITION", in_public=share_public, in_organization=share_organization, in_groups=share_groups)
arcpy.AddMessage("Service published")
return output[5]...so that the function will publish a feature layer rather than the whole map. On running the code I receive the following error:
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\server.py", line 1179, in StageService raise e File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\server.py", line 1176, in StageService retval = convertArcObjectToPythonObject(gp.StageService_server(*gp_fixargs((in_service_definition_draft, out_service_definition, staging_version), True))) File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing_base.py", line 512, in return lambda *args: val(*gp_fixargs(args, True)) arcgisscripting.ExecuteError: ERROR 001272: Analyzer errors were encountered ([{"code":"00102","message":"Selected layer does not contain a required layer type for web feature layer","object":"Map"}]). Failed to execute (StageService).
Failed script Publish Web Feature Layer... Failed to execute (Publish Web Feature Layer).
I can't understand why this is happening as the current map does display the imported feature layer and when running the section of the code under #Reference map to publish in the python console it does find the "Dwellings" feature layer. The line of code which throws the error is:
...and the error message isn't very helpful, I can't find any helpful documentation on Esri's website which details if the problem is with the feature layer or a bug in the code.
I am using ArcGIS Pro 3.1.3 with the default arcgispro-py3 environment.
Below is a diagram of my model:
Below are the parameters I used as per the Esri article:
Any suggestions/assistance would be gratefully received.
Thanks
Andy
