Hello, I have a Highly Available ArcGIS Enterprise stack deployed with ArcGIS Enterprise Cloud Builder for AWS. I am wondering how can I update the licenses for the portal, server, datastore, and webadaptor?
Thank you!
Ualas
The licenses for Portal for ArcGIS can be updated through the Portal UI, ArcGIS Server is updated through the licensing wizard on the machine, ArcGIS DataStore is updated through a command line tool also on the machine, and ArcGIS Web Adaptors don't have a license associated with them.
Portal:
Server:
DataStore:
https://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm#ESRI_SECTION1_3B306C70FBC94A3E95EFCB3448C2B925
Thank you for the reply. I'll try the solution on Thursday and I'll provide feedback.
Hi @ReeseFacendini , your instructions worked great. Thank you!
I am having issues with the server side. I can finally se my layers again in Portal and server manger, but the error in Pro will not go away
@Laura is this for data coming directly from an Enterprise Geodatabase?If so, you need to update the license also in the Enterprise Geodatabase as the SDE user: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/update-enterprise-geodatabase-license.htm.Should take less than a minute to complete.
Yes, SDE. How can I do that without being able to connect to the database?
You will need the SDE user connection. Once you have that, you can apply the keycodes file from ArcGIS Server that was just updated. It will update the license information in database for you.You may need to get IT or an admin to provide you a copy of the keycodes file or access on the machine.
I have the keycodes; I cannot connect under any login
Have you tried to enter the keycodes file in that pop-up window?
