How could I use feature class using ALIAS instead of FieldName in pop up AGOL?
How is your popup configured?
A "field list" element should use the alias by default, and an Arcade element is totally in your control as to what is displayed and how.
You can get the alias of the field by first getting the schema of either the feature or layer.That returns a dictionary of the fields and their names, aliases, types, and other information.
In this example, I'm constructing a list of the field aliases for fields that contain the word "MAX" in the field name and have a value of one.
var theSchema = Schema($feature); var fields = theSchema['fields']; var species = []; for (var i in fields) { if (Find('MAX', fields[i]['name']) > -1 && $feature[fields[i]['name']] == 1) { Push(species,fields[i]['alias']); } }
I don't know, but for me it doesn't. It shows field_name instead
And what would be expression if simple I want to use Alias, without loooking for specific word.
Can you give an example of what content you would like to see in the popup?
