Hello all,
I've done a pretty extensive search but I can't find a way to change the pop-up location for an AGOL web map. Is it not possible?
Is there a way to default to a docked pop-up?
~Jhanek
You can go into the web map's JSON, using something like the AGO Assistant, and edit the popup settings, as detailed in this solution:
https://community.esri.com/t5/arcgis-experience-builder-questions/how-to-change-default-docked-popup-location-in/m-p/1040700/highlight/true#M1665
EDIT: I replied too quickly, that won't help you in an AGOL web map. That setting isn't in the web map's JSON, but the viewer app itself, which you won't have access to in AGOL.
The dock popup in Map Viewer is stored on a browser cache basis and is not stored in the web map at this time.
Thank you both. I have created a web app instead of a web map. Is there a way to have the pop-up open docked by default?
@RussRoberts Is it possible to change the popup location of a map using another app let's an Instant App template?
You can adjust the docking placement in instant apps under the Step 2. About section.
Cheers Russ, this helps 🙂
