Versions: ArcGIS PRO 3.1.0 & Postgres 14
I have a registered feature class in a Feature Dataset. It was first created & registered outside the FD and then dragged in. Then I remove it with ArcGIS PRO (AGP). After that I create the table again from PgAdmin (or another Sql editor). When trying to register the table in AGP I got a message that says "Error 001050 Either registered with database already or cannot open the dataset."
It isn't registered and it does exist. The symbol in front of the table name i AGP Catalog doesn't indicate that it is registrered. The table is at this point empty.
I tried this with a feature class that hasn't been part of a Feature Dataset and then the registration is no problem. Something happens when the feature class has been inside a Feature Dataset. I guess some stuff is not removed from the sde-schema but I can't find where it is.
Any clues on where to search?
