Is there an updated version of Mission Critical Services - Analysis example for 2023.2?
Hi @SteveMcCarthy,> Is there an updated version of Mission Critical Services - Analysis exampleCan you please be more specific? Where did you see this example?
https://arcgismonitor.maps.arcgis.com/home/item.html?id=94a179f3698545ddacc32182f0660200
Similar to this link https://arcgismonitor.maps.arcgis.com/home/item.html?id=94a179f3698545ddacc32182f0660200 only using the new functionality 2023.2.
Hi @SteveMcCarthy,I don't think there were any significant changes in Monitor 2023.2 that would affect the Analysis view. See the ArcGIS Monitor 2023.2 release notes.FYI @AndrewSakowicz for comment.
The documentation for the Mission Critical Analysis says to use the admin utility from the gallery to import the analysis file (step 4). I'm unable to find the admin utility in the gallery (and the link in the doc is broken). Can anyone point me to where I could find the admin utility?
Thank you!
