I am using ArcGIS Pro 3.0.2 and going through the "Use Sewer Utility Network Foundation" to better understand the Utility Network in preparation for migrating from a geometric network to the Utility Network. I followed all the steps up to "Project and Remove Sample Data". When I run that task using the supplied Asset Package as input (Sewer_AssetPackage.gdb) and naming a new Package as output, I get the message "The domain was not found" for each domain in the input database. Was I supposed to load all the domains to the output database before running the task? Thanks for any info you can provide.
