Multiversioned views incorporate database views, stored procedures, triggers, and functions to access a specified version of data in a geodatabase table using Structured Query Language (SQL).
jnderose,I was thinking about my problem and using multiversioned views. Can I get by with not using a MV view if I add all of the records from that layer and did a join field in arctoolbox? I have fields that I need to delete first and then do a join field to get the data field I need filled in? Then syncronize and to update the parent. Would you need to do the schema changes first?ThanksQuinn
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
