I am unable to load image services with ArcGIS online using Google Chrome version: 46.0.2490.71 m. However the image services load fine in Internet Exlplorer version 11.09600.18163.
Claire Inbody - it appears to be a mixed content issue. Chrome is basically blocking the layer from being loaded while IE allows it through (the behavior varies from browser to browser, and even version to version when the browser auto updates).
Try loading the app from the link below (http, instead of https):
http://ndor.maps.arcgis.com/apps/StorytellingSwipe/index.html?appid=8d57a3ffeab4485eb6565eac3feca5dc
Alternatively, you can add the image service using the https url - https://ags3.lincoln.ne.gov/arcgis/rest/services/Aerials/Aerial1964/ImageServer
Adding the image service url over https will help with the blank search issue you referenced above.
Hi Claire,
Can you provide more detail? For example, how are you trying to load your image services? Are you trying to add them as an item to your AGOL Organization? Or, are you trying to add the service directly to a web map? What errors are you receiving?
Jake,
I am trying to add the image service to the web map. I do search for layers, In A GIS Server. Type in the rest service url. It works in IE does not work in Chrome.
Chrome issue above.
IE- No issue.
I created a spyglass app and that app works in IE but errors out in chrome. I believe because it cannot read the image service I am using.
What version of IE are you using? I was able to reference the above URL in IE 11 and display the services. Also, have you tried adding the service by going to Add > Layer From Web? You can paste the entire image service URL there, i.e.:
Aerials/Aerial2013 (ImageServer)
Its chrome that does not work. I can get to work in IE- stated about version 11.
Get this error in chrome:
Sorry, I misread that. Are you able to upgrade to the below version? I was unable to reproduce the issue with this version.
