any idea why this code fails please ?
You don't seem to account for null at all but it is hard to read
Code formatting ... the Community Version - Esri Community
<null> in python is None not a space
if a not in [None, " ", ""]: # then do something
Also, I see the python function, but don't see you calling it:
You need to call update() and pass the variables to it.
R_
Like the others have said, you actually have to call the function, and you should compare to None, not space.
x = [1, None, 2] for y in x: print(y is None) # False # True # False
Also, your function is needlessly complicated. Just use something like this:
# BFS_concat_trial = concat_if_not_empty([!Field1!, !Field2!, !Field3!, !Field4!, !Field5!, !Field6!], [None, "", " "], "/") # code block def concat_if_not_empty(values, empty, separator): """Concatenates non-empty values. values: list of values to concatenate empty: list of values considered empty separator: character used for concatenation """ values = [str(v) for v in values if v not in empty] return separator.join(values)
