Hi all,
Suddenly my layers don't appear in the select, attribute table and screening widgets, anyone is having the same issue, it is a bug or there is a new update of the WAB on the way?
Pablo
Hi Robert, it might help you in the future, the problem was a layer in the layer list without the query capabilities activated.
Pablo,
I have not seen any issue like that.
It is weird, I deleted the select widget and add it again, still the layers doesn't appear, but in the setup wizard I can see them.
What happen if you start a new app?
If I chose a different web map works, but with the same one, still doesn't load the layers in the widgets
Have you restarted the map service(s) that contain the data that the web map uses?
Nothing, it keeps trying to load the layers as below
Can you send a screenshot of your browsers web console error(s)?
Weird, there aren't errors
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
