I'd like to change fields in a list from text to icons. Can this be done in the list widget?
Stabilizing = up arrow (green)
Destabilizing = down arrow (red)
Unchanged = neutral arrows (blue)
Dashboard list widget:
Goal is to get it to look like this:
@jcarlson
@JohannesLindner
@FriederikeAlschner
@DavidNyenhuis1
Of course!
Enable advanced formatting, and put something like this in the expression builder:
// svg code for your icons var green_triangle = `<svg height="30" width="30"> <polygon points="15,0 30,30 0,30" style="fill:lime;" /> </svg>` var red_triangle = `<svg height="30" width="30"> <polygon points="15,30 0,0 30,0" style="fill:coral;" /> </svg>` var blue_triangles = `<svg height="30" width="30"> <polygon points="0,15 14,27 14,3" style="fill:mediumblue;" /> <polygon points="16,27 30,15 16,3" style="fill:mediumblue;" /> </svg>` // set icon var by attribute var icon = Decode($datapoint['your_attribute'], 'stabilizing', green_triangle, 'destabilizing', red_triangle, blue_triangles )
And down in the return section, make sure you include icon in the attributes object. Then in your list item template, just call {expression/icon}.
@jcarlson thank you so much for your help! does this look right:
It looks good. Sorry I didn't have a full example to post, I didn't have a dashboard handy. When you define attributes, you have to refer to them by their key name, not the value. So you need to do expression/attribute1 to access the value.
Oh and Decode needs a default value to apply to anything that doesn't match. You can just add one more parameter to the function for an empty string, '', so that no icon appears if it's null.
@jcarlson - thanks for these tips. Much appreciated
I'm getting closer (just need to get the arrows to display 🙂). See anything that would be preventing them from appearing and the icon text displaying instead?
It sounds like you want three icons? You'd want to use the same Decode function for each separately.
