Can arcade be used to symbolize from a point layer attribute column to a polygon layer on AGOL?
Thank you.
This not possible. featuresets are only available for use on popups. Using another feature to symbolize another layer would not scale.
https://www.esri.com/arcgis-blog/products/arcgis-living-atlas/data-management/pump-up-your-pop-ups-with-arcade-featuresets-and-living-atlas-part-2/
