Četl jsem různé články od Esri, ale nefunguje to. Čelím výzvě uvedené výše. Zkoušel jsem smazat a vytvořit nový prostorový index na třídě prvků. Ale nic se nezměnilo. Přiložený dokument níže <\/SPAN><\/P>
First, you should report this issue to Esri support. They will need full details and more than likely a copy of your database.
If you have two tiers in your network, Transmission and Distribution, and you enable the topology and then run update subnetwork in the distribution tier first, then try to run update in the Transmission tier on a subnetwork, you could encounter this error. You could also encounter in the same tier if the first subnetwork processed has a very small extent. You should try starting with running update subnetwork with the subnetwork that probably has the largest extent.
But again, please submit an issue to Esri support.
Hi @RomuldKiobya
You should delete the spatial index in the subnetline feature class. Then you can run the update subnetwork tool. it will not give an error. When you see that it doesn't give an error, you can recreate the spatial index.
