WebApp Builder has a "Create a custom filter" function (1) that allows the users to define their own filters. Is it planned to have this functionality also implemented in the ArcGIS experience builder?
(1) https://doc.arcgis.com/en/web-appbuilder/create-apps/widget-filter.htm
I would like to second this request, this is a real issue on a project I'm working on: users would like to create their own filters within Experience Builder but this is not currently possible as far as I can tell.
Yes, this functionality is extremely important and having an equivalent in EB is essential for being able to migrate over to the new technology from WAB!
Chiming in here. Having to pre-define filters isn't worthless, but almost. Our users need to explore different aspects of data so they need to be able to generate their own criteria.
Hi all,
Custom filters can now be set at run time with the Filter widget on November 2024 ArcGIS Online.
Please follow the steps below:
1. Add a Filter widget, click the New custom filter button to create a custom filter.
2. Select the data that you want users to use to make custom filters at run time. You can select multiple data sources.
3. Turn on Live view or Preview.
4. You could create the clause or clause set at run time.
Ke
Přihlaste se, abyste mohli přispívat, sledovat obsah a další. Jste tu noví? Zaregistrujte se zdarma.
