attr dim = 10 Cutter --> split(x, noAdjust) {~dim : split(z) {~dim : Cut. }* }*
I'm using your code to try to split up my polygons into a grid so that I can better align it to the terrain. However, you say to use the right mouse button to convert this grid back to a shape. What exactly do you mean? I do not see any option to convert the grid back to shape.
Matthias Buehler
Maybe you are looking for Shapes -> Convert Model to Shapes
Ohh okay, I am starting to understand now. Do you know if it's possible to get rid of this grid though?
I want it to look more like this layer but with the detail from the grid above
For terrain, set the Wireframe Alpha (in the Inspector) for the terrain layer to 0.
Or for models, turn off the wireframe on models in the Settings drop down in the Viewport (keyboard shortcut 7).
