I want to create a Field Map, however when I go into My Content to create a feature layer, I only get the buttons New item and Create App. If I click on them, there is nothing about feature layers for me at all. Why is that?
When you click on New Item > there should be a button towards the bottom of the window that says Feature Layer (above Developer credentials)
If the Feature layer option is not available, it might be a permissions thing!
Thank you for taking the time to reply! Unfortunately this is all I get when I click on it.
Hi @TitasBrokevicius
What is your role and usertype?
You will need to change your role and usertype depending on what they are.
Please find linked to documentation that outlines the various usertypes and roles within ArcGIS Online, which outlines the different privileges each role and usertytpe has.
User types, roles, and privileges
As @DanielFox1 said - it is a permissions issue! You'll need to have the permissions assigned to upload data in this case.
I also think if you are just on the regular free ArcGIS Online (a non-organization account) the option to upload data to a feature layer will not be available because it requires storage credits.
