I would like to know if there is a way to catch any widget open and close events?
Thank you,
Maxime
Maxime,
For open yes.
topic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">subscribe</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'openWidget'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//do something</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
There is nothing in place that you can use for all widget on close.
Thank you Robert!
Need same thing in experience builder.. onClose Event
