ArcGIS Pro has tools for working with M values. Are these functionalities available in arcpy?
Think you'll have to do it manually with a cursor and extracting the m from the point. Stealing a post from SO
lyr = r"C:\Users\...\Default.gdb\TEST_ROUTE" fields = ['SHAPE@'] with arcpy.da.UpdateCursor(lyr, fields) as cursor: for row in cursor: partslist = [] partlist = [] array = None feat = row[0] partnum = 0 # Count the number of points in the current multipart feature partcount = feat.partCount pntcount = 0 # Enter while loop for each part in the feature (if a singlepart feature # this will occur only once) # while partnum < partcount: part = feat.getPart(partnum) pnt = part.next() # Enter while loop for each vertex # while pnt: pntcount += 1 if not numpy.isnan(pnt.M): partlist.append(arcpy.Point(pnt.X, pnt.Y, pnt.Z, pnt.M / 1000)) pnt = part.next() # If pnt is null, either the part is finished or there is an # interior ring # if not pnt: pnt = part.next() partslist.append(arcpy.Array(partlist)) array = arcpy.Array(partslist) partlist = [] partnum += 1 polylinefeat = arcpy.Polyline(array) row[0] = polylinefeat cursor.updateRow(row)
This seems to do what I want. Thank you!
