is this link below that goes to the ArcGIS Monitor Gallery outdated? This looks like things that worked with prior releases and not 2023 version. Is there a new gallery that works only with 2023?
@DerekLaw
Here is the link to the ArcGIS Monitor 2023 gallery, but ArcGIS Monitor 2023 doesn't support extensions like the 10.8.1 version did. If there is functionality that you'd like to see added to the new generation, please use this Ideas page https://community.esri.com/t5/arcgis-monitor-ideas/idb-p/arcgis-monitor-ideas
Hi @Anonymous User, @ReeseFacendini's post is correct. The add-ins found in the old ArcGIS Monitor gallery do not work with ArcGIS Monitor 2023. He shared a link to a couple of unsupported dev samples available in the ArcGIS Monitor 2023 gallery.Hope this helps,
Hello Y'all ,
I know MissionCriticalAnalysis is not supported. But I would love to get help on it.
I'm getting this error:
C:\ArcGISMonitorExamplesExtras_Tarig\arcgis-monitor-admin-utility\dist>AdminUtility -f SampleConfig.json -o analysisInvalid \escape: line 9 column 20 (char 178)Traceback (most recent call last):File "AdminUtility.py", line 8, in mainFile "Modules\Builder\builder.py", line 18, in __init__File "Modules\Builder\builder.py", line 75, in _get_configFile "Modules\Inputs\init_config.py", line 6, in __init__File "Modules\Inputs\init_config.py", line 10, in _read_config_fileFile "Modules\Helper\helper.py", line 37, in read_config_fileFile "json\__init__.py", line 293, in loadFile "json\__init__.py", line 346, in loadsFile "json\decoder.py", line 337, in decodeFile "json\decoder.py", line 353, in raw_decodejson.decoder.JSONDecodeError: Invalid \escape: line 9 column 20 (char 178)NoneTraceback (most recent call last):File "AdminUtility.py", line 8, in mainFile "Modules\Builder\builder.py", line 18, in __init__File "Modules\Builder\builder.py", line 75, in _get_configFile "Modules\Inputs\init_config.py", line 6, in __init__File "Modules\Inputs\init_config.py", line 10, in _read_config_fileFile "Modules\Helper\helper.py", line 37, in read_config_fileFile "json\__init__.py", line 293, in loadFile "json\__init__.py", line 346, in loadsFile "json\decoder.py", line 337, in decodeFile "json\decoder.py", line 353, in raw_decodejson.decoder.JSONDecodeError: Invalid \escape: line 9 column 20 (char 178)
Here's my sampleConfig.json:
{"server":{"url":"http://memgisazmonitor:30080","username": "gismonitor","password": "#gismonitor123!"},"analysis":[{"file":"C:\ArcGISMonitorExamplesExtras_Tarig\arcgis-monitor-admin-utility\dist\MissionCriticalServices.json"}],
Kind regards,
Tarig Ahmed, GISP
GIS Administrator
Information Technology Division
150 Peabody Place, 1st FloorMemphis, TN 38103
(C) (469) 261.0849Tarig.Ahmed@memphistn.gov
