Domain=com.Esri.ArcGIS.ErrorDomain Code=10003 "Failed to open file. May not be a valid tile package." UserInfo=0x9ac7850 {NSLocalizedDescription=Failed to open file. May not be a valid tile package.
Curious if there has been any progress figuring out why .tpk files larger than 2GB can't display using the iOS SDK. This issue is having a serious impact on the apps we produce.Also - we've been detecting some pretty steady memory leaks from tile extraction processes when using .tpk files in the 10.1.1 SDK.-Mike
