I might be missing something really simple here.... Using the Indoors Viewer, why can't I search for units by UNIT_ID? It appears that all I can search by is NAME. We have a specific use case where we want users to be able to search by the UNIT_ID.
Hello @Andrew-Bowne,
You can use "Configure Indoors Categories" tool to configure search fields and suggestion templates.
You can check below documentation.
https://pro.arcgis.com/en/pro-app/3.0/help/data/indoors/create-an-indoors-category.htm
Does this mean that UNITS need to be configured as Indoors Categories? By default, UNITS are searchable - but it only seems that they can be searched by NAME
I am not sure but it might be true if you used default template map provided with ArcGIS Indoors. Otherwise you have to set manually. When you create default indoors categories it uses NAME filed by default. You have to set manually for other fields.
Looks like you have to create an indoor category in order to modify the search attributes. I was hoping to not have to create a new category. It doesn't look like that's the case.
