I need to use Arc Gis Pro Images and Icons but I don't know where or how to get them
Examples of these Icons :
Build and run this sample: arcgis-pro-sdk-community-samples/Framework at master · Esri/arcgis-pro-sdk-community-samples (github.com)
Scroll down on the link above to get instructions on how to run the sample. This will give you the most complete list of Pro Images.
Starting with 3.1 the syntax on how to use Pro Internal Images changed a bit (internally all images were converted into vector graphics), and you can find instructions on how to reference Pro internal images here:
ProGuide Content and Image Resources · Esri/arcgis-pro-sdk Wiki (github.com)
You can find ArcGIS Pro icon images and names here:
https://github.com/Esri/arcgis-pro-sdk/wiki/DAML-ID-Reference-Icons
In daml file it could look like that:
<button id="your_button_Id" caption="your_button_name" className="your_button_class" loadOnClick="false" smallImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/DataReviewerImportRules16.png" largeImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/DataReviewerImportRules32.png" condition="esri_mapping_mapPane"> <tooltip heading=""><disabledText /></tooltip> </button>
In xaml it could look like that:
<Image Source="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/MoveFromFolder16.png" Stretch="None" />
