The map provides coverage for the world down to a scale of ~1:72k. Coverage is provided down to ~1:4k for the following areas: Australia and New Zealand; Europe; Canada; Mexico; United States; parts of Southern Africa including Botswana, Lesotho, Namibia, South Africa, and Swaziland; and parts of South America including Argentina, Brazil, Chile, Colombia, and Venezuela. Coverage down to ~1:1k and ~1:2k is available in select urban areas.
Mike - I have a related question and this thread is the closest thing I've seen. I have published a layer of proposed infrastructure projects to a public web map using ArcGIS Online. Some residents complain that when they do an address search the result is at so large a scale that they have to zoom out several steps to see any projects. How can I limit the maximum scale at which the web map will display? Setting the Scale Range for the feature class only controls whether the layer is shown at all in beyond a given scale (e.g., 1:24,000). I need something that prevents ArcGIS Online from displaying in closer than 1:24,000. Thanks!
Michael
There is currently no way to restrict the maximum scale. This has been discussed by our team and we have it written up as an enhancement, but it just hasn't been implemented.
What is the current maximum scale of your basemap? Are you using something custom?
Mike
This would be a very helpful function to add. I have a Tile Layer that disappears at 1:1028 and I would like to stop folks from zooming in beyond that level. That said, is there a way to make my Tile Layer appear at higher scales?
Bill
Hi Mike.
I was googling this issue and landed on here.
Will there be an update/configuration tool for this in a future?
I tried couple available web apps and also the ArcGIS Online Assistant, but couldn't solve the issue.
wbgisuser as far as I know there have been no updates on this idea for either setting a maximum scale, or allowing zooming in beyond the maximum scale of the basemap.
It seem like 5 years later there has been fix for this issue.I'd like to be able to set the maximum zoom for a search in Map Viewer classic.Will the new Map Viewer get this functionality.
Thanks.
