I've tried in both Chrome and Edge, but the save button disappears and doesn't come back when I change the basemap. Why would this happen? Does this happen to anyone else? Is this a bug?
thanks for bringing this up! Making a note of it 🙂
@Teresa_BladerActually I do see your issue, does this only happen if you are on the layers tab instead of the legends tab for example
Oh yes, that is true. Weird! I guess for now I can toggle back and forth between the icons! Mostly I just need to find my features in the map... which are no where near (0,0) lat long. 😁
@bbollin I misspoke. This happens on the "Visualization" tab for the feature layer. I'll correct my post. This is happening on several feature layers I just tried. Doesn't seem to matter if it's hosted or hosted view. And the map extent always starts at (0,0) for the extent which is a bit confusing.
Hi there, I cannot reproduce your issue. Is this something you are seeing on every feature layer or just the one in the screenshot?
