Does anybody know why these two things have blow rectangles around them at the bottom of my Hub page? Anybody ever seen this, or any other color?
@ArmstKP Embedded styles within the Text Card are not contained to the Text Card; they will apply to the entire page if your selectors are generic. Our application uses a lot of the common HTML elements, so that is likely what is happening if you've attached styles to the button element. You can prevent this from happening by adding a unique class name to the row containing your Text Card and then referencing that row in your CSS to limit how the styles are applied.Example of generic selector usagebutton {background-color: blue; color: gray}Example of targeted selector using row class.uniqueRowClassName button {background-color: blue; color: gray}
Do you have any custom CSS on your page in Text Cards or in your header that affects buttons or perhaps uses a !important? That looks like the result of custom CSS being applied to generic selectors without enough specificity.
@KlaraSchmitt I do have custom CSS for one button on the page. I thought that would only effect that object or section of code, not the Explore Feeds and Manage Privacy section...?
