Good Morning
Simple question. Does the latest version of ArcPro support Zarr files in the multidimensional raster tool ?
Regards.
Jeremy.
Yep, you can create a multidimensional raster layer: https://pro.arcgis.com/en/pro-app/latest/help/analysis/image-analyst/an-overview-of-multidimensional-raster-data.htm
Tool Reference: https://pro.arcgis.com/en/pro-app/latest/tool-reference/multidimension/make-multidimensional-raster-layer.htm
Cheers George,
Although I am having difficulty opening a .zarr file I have. I'm just trying to figure out if it is an issue with ArcPro or the file itself. Being new to Zarr files I assume ArcPro just reads the folder containing the relevant information with it.
Hi Jeremy - I have directly worked with Zarr data yet, I do have large clients testing / using Zarr data now.I will say that there could be something in the Zarr file that Pro does not like. I have seen this with other formats. Maybe a recommendation would be to contact technical support to work with them on this.
