I am having an issue with Topology rules when there are sub types on my fabric connection lines and points. In my model I have 2 connection line subtypes, tie line and road centerlines. But only one sub type is being added to the topology attribute rules when I enable fabric topology. No rule is create for the other sub type and I cannot add others
Further more I have 3 fabric point subtypes. I would like to also create custom rules for these type but they do not appear in the the standard topology rules.
When I try to manually create or modify rules they are disabled. The attached screen grab shows the default rules that are created. Only the parcel line road subtype is added. The Remove rule button is grayed out and the Add rule button doesn't do anything. No new windows appears for adding rules.
So my questions are
1. Are subtypes supported in Parcel Fabric lines and points
2. Is the parcel fabric topology modifiable?
I am using ArcGIS Pro 3.0 version of the fabric and I have tried this in both FGDB and EGDB copies of my data.
