# -*- coding: utf-8 -*-
Created on Wed Jul 14 15:57:33 2021
@author: LESNIAM
import geopandas as gpd
#import arcpy
import mapping_module1 as MM
from IPython.display import display
#from arcpy.display import display
gdf_corr = gpd.read_file('G:\Jason Ma\2022Q3 HERE shapefiles\Corridors\Old corridors\Toronto1.shp')
corridor_name = 'Toronto1'
gdf_corridor_sorted = MM.Order_the_Links(corridor_name,gdf_corr)
display(gdf_corridor_sorted)
gdf_corridor_sorted.to_file('G:\Jason Ma\2022Q3 HERE shapefiles\Corridors\Old corridors\Toronto1_done.shp')
output:
Runtime error
File "<string>", line 14, in <module>
File "C:\Python27\ArcGIS10.8\lib\site-packages\geopandas\io\file.py", line 76, in read_file
with reader(path_or_bytes, **kwargs) as features:
File "C:\Python27\ArcGIS10.8\lib\site-packages\fiona\env.py", line 398, in wrapper
return f(*args, **kwargs)
File "C:\Python27\ArcGIS10.8\lib\site-packages\fiona\__init__.py", line 257, in open
layer=layer, enabled_drivers=enabled_drivers, **kwargs)
File "C:\Python27\ArcGIS10.8\lib\site-packages\fiona\collection.py", line 154, in __init__
self.session.start(self, **kwargs)
File "fiona\ogrext.pyx", line 466, in fiona.ogrext.Session.start
UnicodeDecodeError: 'ascii' codec can't decode byte 0x82 in position 11: ordinal not in range(128)
There unifcode error that something wrong with the range I believe , this is something new, I not sure if I change the decoding or something ? Any help and suggestion would be helpful , Thanks for the time , it worked with other shape file but not this one
