Hello,
I checked our ArcGIS Server Manager logs and noticed the following error message (see attached).
Anyone understand what this is trying to indicate or the resolution?
Everything seems to be running fine.
Thank you.
Jeff
@JD1016 Its hard to tell from the info in the error message. You will need to share more columns from the log to get a better idea of what caused the error. For example, which service triggered the errors? If you look at the arcgis server logs in the ArcGIS Server Admin interface you will get more info / more columns. And I find it easier to browse and scroll through the log with the Admin interface.
It could just be that one user is trying to do something that is unsupported. Not really a big deal unless it happens a lot or if these requests take a long time to execute. Every night we run a query on the web logs on our web adaptors to extract all of the requests that took more than 60 seconds to execute. I review these daily to see if I can identify problems that can be fixed. The list of long running requests is usually only a few records but sometimes it will be a few dozen.
Bernie.
Hi Bernie,
I've never looked at the logs in Admin.
I've logged into Admin, I see logs...where do I go from there?
Thanks.
Having problems with the Start Time and End Time. I keep getting "startTime must be epoch time or an ArcGIS server timestamp.
As an example, I put in "Dec 14, 2022, 10:53:53 AM" from my ArcGIS Server Manager but it does not like that form.
Any suggestions?
Unfortunately, that did not work either. However, I did find an online converter that takes the data and time converts it over to a UNIX time stamp (epoch). After applying those times it does kick out the columns you indicated but they are all blank underneath.
Through the API Reference, the Log Codes, or Process IDs or Request IDs are required. Any idea on that component?
Unfortunately the error code definitions for 9001 and 9003 don't give any more info than what is displayed in the log "Mesage" column. You may want to try and match these errors by date and time with the web logs on your web adaptors. Try to see what requests were arriving about the same time.
Yeah, I caught that too. They basically codify what they are already spelling out in ArcGIS Server Manager ever so cryptically. Thanks.
