Error #100160 is occurring while importing longitudinal and latitudinal as shapefile.
I did all the necessary procedures.
Check the screenshot
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
an invalid coordinate system was specified according to the help. Show the table and the inputs to the tool dialog to track down the error
Dan, A C/S was fed. (Check the screenshot). The inputs are fine as they worked on ArcMap standalone.
The attached ZIP contains the XLS file.
the points are not in decimal degrees, so you have to specify an appropriate coordinate system. perhaps it was a projected source like web mercator? Check
Yes, I kept those as Northing and Easting.
I assigned a new P/S from the list but the same happened.
