Hello,
I am using Arcgis Pro 3.0 with aviation charting extension. And I am trying to create a Chart Type A.
The problem is for the multipatch feature class "ObstructionidSurface_MP" do not generate the PROFILEJSON after creating the OIS Profile Data.
Thank you for your help.
Ensure that you are using an input DEM. Also increase the size of the PROFILEJSON field. If the tool generates too large a string to fit in the field size, it will not update the field. Or try it again with a larger sampling distance.
