Hi Russell
I understand that we should not add following layer under MyContent of ArcGIS Online because AGO basemaps are offline capable
https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer
However, we are using AGE portal for our organisation and i need a offline enabled basemap for collector but when i am adding this service under my content of AGE it is asking for the credentials and no credentials seems to be working here. May i know the reason why?? token error is coming but my AGE and AGO both are setup with SSO to our AD.
OR is this also not a suggested way? because esri page says otherwise
https://doc.arcgis.com/en/collector-classic/windows/create-maps/offline-map-prep.htm
please go through the last section of this url......Use an Esri basemap with ArcGIS Enterprise
BR
Saurabh
