Dilson, Though you can get UNC paths to work you really should setup a virtual directory so that instead you can use a proper url for the photo in that field. Can you provide an example of what one of your actual PHOTO paths looks like?
<?xml version="1.0" ?> <configuration> <title>{NAME}</title> <description> <=!=[=C=D=A=T=A=[<p><b>Parcel Address: </b>{ADDRESS_3}</p><p><b>Owner Name: </b>{NAME}</p><p><b>Parcel Number: </b>{PARCEL_NUMBER}</p>]=]=> </description> <fields> <field name="ADDRESS_3" visible="false"/> <field name="NAME" visible="false"/> <field name="PARCEL_NUMBER" visible="false"/> <field name="URL" visible="false"/> </fields> <medias> <media type="image" caption="Image PPIN {PPIN}" imagesource="http://gislap183/Assets/Images/{URL}" imagelink="http://gislap183/Assets/Images/{URL}"/> </medias> </configuration>
Dilson, The only thing I see that is missing from the XML is the fields list. Here is an example I have working on my end. The BIG difference to note is I am using a virtual directory to gain a TRUE url. Using UNC paths or file paths is possible but different based on the browser. Firefox for example needs /// in the path "file:///c:/Assets/images/IMG_3663.jpg" where other browsers do not. This is why it is ill advised to use actual file paths or UNC path when in a web browser solution like Flex.<?xml version="1.0" ?> <configuration> <title>{NAME}</title> <description> <=!=[=C=D=A=T=A=[<p><b>Parcel Address: </b>{ADDRESS_3}</p><p><b>Owner Name: </b>{NAME}</p><p><b>Parcel Number: </b>{PARCEL_NUMBER}</p>]=]=> </description> <fields> <field name="ADDRESS_3" visible="false"/> <field name="NAME" visible="false"/> <field name="PARCEL_NUMBER" visible="false"/> <field name="URL" visible="false"/> </fields> <medias> <media type="image" caption="Image PPIN {PPIN}" imagesource="http://gislap183/Assets/Images/{URL}" imagelink="http://gislap183/Assets/Images/{URL}"/> </medias> </configuration>Here is a link to setting up a virtual directory on Apache:http://w3shaman.com/article/creating-virtual-directory-apache
