I would like to add the symbol automatically for each item in the list widget in ArcGIS Experience Builder. However, I can not find the function in ArcGIS Experience Builder. While the symbol icon for the list exists at ArcGIS Dashboard.
Can anybody find it for me. Thanks.
Hi @gzhangmfi ,
In Experience Builder, the symbol icon isn't an option in the list widget, but you can configure one with the image widget.
Please see below for the image widget settings:
Hope it helps,
Shengdi
Thanks Shengdi,
I added an image widget beside the text widget in a list widget, however, I could not select a specific field to set up the symbol. I would like the symbol color adjusting with the order type (alert or order) which is under the "type" field.
I followed your suggestion, however it can not add the symbol as I like to see. Would you mind to help me for below issues?
Grace Zhang
Hi Grace,
Did you find a solution to this problem? I'm experiencing the same thing.
Thank you,
Julia
