I need to create a layer in ArcGIS Online that uses WGS84 as the coordinate system because another system will be accessing the data daily to update their system and they use WGS84.
Looking around in the community I found this post that says:
If you publish SD file with a specific projection and transformation parameters, online feature service will preserve the spatial reference of the map defined within the SD file. We will not default the online feature service to 102100 in this case.
Publishing any other data source (shapefile, filegdb, excel, etc.), we will default to mercator (102100 or latest=3857), unless you pass a tergetSR publishing params.
I don't see any publishing parameters in ArcGIS Pro for target SR, nor do I see any projection or transformation parameters when I try to save as a service definition file. Can someone point me in the right direction to make this happen?
I have tried with sharing just the layer and also with saving a new map with the layer all with the proper WGS84 GCS.
Any help would be greatly appreciated.
Thanks!
~Brandon
