ArcGIS Pro 2.8.4: An option to display the tbx file path of an open model,
It would be great if an option to display the tbx file path of an open model get available.
For example, how to identify the path of tbx file of the open marked model in the screenshot below?
Also discussed here:
ArcGIS Pro 2.8.4: How to identify where an OPEN model is saved on the hard drive?
Hover over the model tab to display the path of an open model:
You noted that you are using 2.8.x. I don't recall when this became available so if you don't see it there, you will need to upgrade. My screenshot is from 3.0 but I'm sure this was available before 3.0.
Thank you KoryKramer for the input. Great. Resolved
Přihlaste se pro psaní příspěvků, sledování obsahu a další. Jste tu noví? Zaregistrujte se zdarma.
