Is there a simple way to export the layer list from a web map (built with WAB) to a text file?
open the feature service in arcmap (in catalog you will see an option for feature services, then use arcpy to list the layers
Is there a way to do this for all services at once? Thanks!
Do you have access to ArcGIS Pro or ArcGIS Notebook (in AGOL or enterprise)? If so this can be done using the ArcGIS API for Python pretty easily!
Yes, I have both of those. Any help is appreciated!! Thank you!
Easy then!
<SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> GIS <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>mapping <SPAN class="keyword token">import</SPAN> WebMap gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'pro'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="comment token"># if running this from Notebook for ArcGIS in AGOL/Enterprise, replace this line with gis = GIS('home')</SPAN> wmItemId <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN> <SPAN class="comment token">#put the id of the webmap in here</SPAN> wmItem <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>wmItemId<SPAN class="punctuation token">)</SPAN> wm <SPAN class="operator token">=</SPAN> WebMap<SPAN class="punctuation token">(</SPAN>wmItem<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> wm<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>lyr<SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I wrote that to be run from the Python window in Pro, but see my note in line 3 about using it in ArcGIS Notebook. Just put the ID of the web map item into line 4 and it should print out all the layers for the given webmap.
I took your script and tried adding in a lyr.url to get the url of the layers and it worked but sometimes it comes up with an exception saying "layer" instance has no attribute 'url' and I was wondering if you know what I can do to put an exception in there. Thanks!
Hi Kayden, sorry for the delay, didn't see your message until now. I've had this issue in the past with vector tile layers (possibly from the basemap?) as they have an attribute called "styleUrl" instead of "url", which you could handle with some code like this:
if layer['layerType'] == "VectorTileLayer": print(layer.styleUrl) else: print(layer.url)
@JoshuaSharp-Heward Thanks this is pretty good.sorry to bother you with this. Do you know how can I run this for my whole arcgis online webmaps? Instead of manually copy paste ItemId for each webmap.
Thanks again for your help
You can loop through all of the webmaps in your arcgis online by using the following code:
web_maps = gis.content.search(query="", item_type="Web Map", max_items=10000) for item in web_maps: wm = WebMap(item)
Then use the rest of the code that you have been using! If you have any issues you can refer back to this code in github that I put together which searches through web maps for a particular web service https://github.com/joshsharpheward/gis-administration/blob/master/search_webmaps_for_services.py
Cheers,
Josh
