Is there any easy way to remove this footer?
Hi @Lindsay,You can turn that off by going to your site's Layout Editor. Then select Settings > Interactions and disable the Product Branding toggle.
Thanks @KlaraSchmitt .. how do I move the footer all together? I thought it might be here, but doesn't look like it.
@Lindsay ,
Ah. In the screenshot you've shared, that actually pertains to whether or not you want a custom footer on your site. Unfortunately, you cannot remove the product footer as it is required by data privacy laws. https://doc.arcgis.com/en/hub/sites/configure-consent-notice-and-product-footer.htm#ESRI_SECTION1_361BFEFACC334AD2B619C89C50D0E8F9
@KlaraSchmitt Ok. Thanks for confirming that. I might try to go into the settings/footer/css area to get the footer colour to match the backgrounds of what I've embedded into the pages.
Is this the best place to do it for the site or do I need to do it page by page?
@Lindsay Customization of the header and footer occurs at the site level. It then carries across all pages associated with the site.
