Greetings to all, in your opinion, what is the best site for providing land use data for any region in the world, and I hope that such data will be provided to the two countries of Iraq - the city of Dohuk. Thank you very much, please help.
You could check Esri Land Cover - Sentinel-2 10-Meter Land Use/Land Cover. It contains an annual 10-meter resolution map of Earth's land surface from 2017-2021(Global Data).
Source Image Layer: https://www.arcgis.com/home/item.html?id=d3da5dd386d140cf93fc9ecbf8da5e31
REST URL: https://env1.arcgis.com/arcgis/rest/services/Sentinel2_10m_LandCover/ImageServer
Also it can be accessed from ArcGIS Pro (ArcGIS Living Atlas)
Greetings, I really don't know how to thank you Mr. Jayanta for this reply and help. Thank you very much and may God protect you. Greetings, I will work on these links and projects implementation Thank you very much.
