Hello
In ArcGis Desktop I can create a dialog box using Python and Tkinter.
Can I do something similar in ArcGis Pro?
Apparently I can't use Tkinter in ArcGis Pro, I can't import it, but is there an equivalent alternative?
ArcGIS Pro uses Python 3.X (ArcMap uses 2.7.X I think). TKinter was renamed to tkinter.
You could try using that. In my experience, Pro and Python guis don't play very well together. Save your work before you try, there's a good chance Pro will crash or freeze.
I belive the way to do something like that would be writing your own AddIn.
But that seems like a lot of hassle for a simple dialog window.
For a simple message box, something like this could suffice:
import webbrowser def open_dialog_box(message): path = "H:/dialog_box.txt" # some location you have write access to with open(path, "w") as f: f.write(message) webbrowser.open(path) open_dialog_box("Hey there!")
Thanks, this works!!!I have to study the addins
