Could someone point me in the right direction on how I would do this?
>>> import math >>> help(math)
# culvert.py # create culvert lines from point events # must have loc_angle and length_m fields # default length_m is 10 metres # angle is from event wizard which is parallel to road # which must be wrong at 9.1 # Input # arg1 point event layer # arg2 loc_angle field # arg3 length_m field # arg4 output featureclass # projection from event layer # Kim Ollivier # 26 September 2006 import sys, string, os, win32com.client, math def newculvert(strID,strX,strY,strAngle,strSize) : """ Create a line array at right angles to angle and add to new featureclass already defined """ id = int(strID) x0 = float(strX) y0 = float(strY) radAngle = float(strAngle) / 180.0 * 3.14159 size = float(strSize) / 2.0 if size == 0 : size = 10 x1 = x0 - size * math.cos(radAngle) y1 = y0 - size * math.sin(radAngle) x2 = x0 + size * math.cos(radAngle) y2 = y0 + size * math.sin(radAngle) # print "%8d %12.3f %12.3f %8.3f %4.1f" % (id,x0,y0,angle,size) # print " %12.3f %12.3f %12.3f %12.3f" % (dx1,dy1,dx2,dy2) print >> f1,"%d 0" % id print >> f1,"0 %f %f 0.0 0.0" % (x1,y1) print >> f1,"1 %f %f 0.0 0.0" % (x2,y2) return True #----------------- main ----------------- gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1") if len(sys.argv) != 6 : print "Need 6 parameters, setting defaults for debugging" strInputFeatureClass = "e:/council/clutha/shape/culvert3.shp" strIDField = "DRAIN_ID" strAngleField = "LOC_ANGLE" strSizeField = "LENGTH_M" strOutputFeatureClass = "e:/council/clutha/shape/culvert_ln.shp" else : strInputFeatureClass = sys.argv[1] strIDField = sys.argv[2] strAngleField = sys.argv[3] strSizeField = sys.argv[4] strOutputFeatureClass = sys.argv[5] if not os.path.exists(strInputFeatureClass) : print strInputFeatureClass,"not found" sys.exit() # set the directory and workspace to the source shapefile location os.chdir(os.path.dirname(strInputFeatureClass)) gp.Workspace = os.path.dirname(strInputFeatureClass) f1 = open("culvert.txt","w") print >> f1,"Polyline" # Find the name of the shape field using Describe. strShapeFieldName = gp.Describe(strInputFeatureClass).ShapeFieldName # Check other fields are correct eFlds = gp.ListFields(strInputFeatureClass) fld = eFlds.Next() fldOk = False print gp.GetCount_management(strInputFeatureClass),"gp count" while fld : if fld.Name.upper() == strIDField.upper() : fldIDOk = True if fld.Name.upper() == strAngleField.upper() : fldAngleOk = True if fld.Name.upper() == strSizeField.upper() : fldSizeOk = True fld = eFlds.Next() if not fldIDOk: strErr = "No ID field found "+strIDField gp.AddError(strErr) print strErr else : print strIDField," found" if not fldAngleOk: strErr = "No Angle field found "+strAngleField gp.AddError(strErr) print strErr else : print strAngleField," found" if not fldSizeOk: strErr = "No Size field found "+strSizeField gp.AddError(strErr) print strErr else : print strSizeField," found" if not (fldIDOk or fldAngleOk or fldSizeOk) : print "Fatal error in field names" sys.exit(2) nCulvert = 0 # open a Search Cursor objRowList = gp.SearchCursor(strInputFeatureClass) objRow = objRowList.Next() # try : while objRow: objGeometry = objRow.GetValue(strShapeFieldName) objPart = objGeometry.GetPart(0) strX = objPart.X strY = objPart.Y strID = objRow.getValue(strIDField) strAngle = objRow.GetValue(strAngleField) strSize = objRow.GetValue(strSizeField) # create a new line feature ok = newculvert(strID,strX,strY,strAngle,strSize) if ok : nCulvert += 1 # cleanup or looks like a memory leak del objRow, objPart, objGeometry objRow = objRowList.Next() except Exception, e : print e gp.AddError(e) del objRow, objPart, objGeometry print "Error in Search Cursor" print gp.GetMessages() gp.AddError("Error in Search Cursor") sys.exit(2) print >> f1,"END" f1.close() print nCulvert,"culverts total" gp.AddMessage(str(nCulvert)+" culverts found") # create a shapefile gp.OverwriteOutput = 1 test = "culvert_ln.shp" gp.CreateFeaturesFromTextFile("culvert.txt",".",test,"") print "Created new shapefile",test #==================================================
